C9300 LLDP
nathanmonteyne0
Hi All,
Most of the time i'm working with CDP but the customer wants to have that disabled and start using LLDP.
They asked if it's possible to hide the hostname and management addresses in LLDP is it possible to fine tune LLDP more?
Or is it just it is on or off?
the reason why they want it is because they say security
Kind regards,
Nathan
M02@rt37
Hello @nathanmonteyne0,
Unlike CDP, LLDP provides more flexibility when it comes to fine-tuning and securing the information it advertises. You can control the information sent by LLDP, including the hostname and management addresses.
LLDP uses TLVs to convey information. By default TLVs are enable. So, you can selectively  disable specific TLVs to control the information exchanged:
Router(config-if)# no lldp tlv-select management-address
To hide the system name (hostname) TLV in LLDP:
Router(config-if)# no lldp tlv-select system-name
Note, depend of the model/platoform you don't have the same TLVs.
In terms of security, better is to disable CDP and LLDP...except for a specific goal (VoIP).
Best regards
M02@rt37
Best regards
Blue_Bird
The following configuration example shows how to enable LLDP on a device; disable LLDP on some interfaces; configure optional parameters such as hold time, delay time, and update frequency; and disable several LLDP TLVs:
switch(config)# feature lldp
switch(config)# interface ethernet 7/9
switch(config-if)# no lldp transmit
switch(config-if)# no lldp receive
switch(config-if)# exit
switch(config)# interface ethernet 7/10
switch(config)# lldp holdtime 200
switch(config)# lldp reinit 5
switch(config)# lldp timer 50
switch(config)# no lldp tlv-select port-vlan
switch(config)# no lldp tlv-select system-name
Best regards
******* If This Helps, Please Rate *******
