How can I create a multi line banner?
ryan.chaney
I am using the following:
action 1.0 cli command "banner exec Z text1 text2 text3 Z"
I would like the text to appear as:
text1
text2
text3
What do I need to change to be able to do this?
Ryan
Jeff Van Houten
Level 5
Level 5
Force a line feed with either or I forget which.
Neither of these work.
router(config-applet)#action 91.3 cli command "banner exec Z
Warning: Assumed end-quote for quoted string
chaney-xtr(config-applet)#
Ok this works:
action 91.3 cli command "banner exec Z\x0aCurrent ADSL speed is $dsl_rate Mbps Noise Margin is $noise_margin dB, $carrier_transitions WAN interface resets since counters last cleared \x0aZ"
