How do I access my Amped Wireless Range Extender?
Users are recommended to periodically update the firmware of their Amped router to add on more features and update the existing features on your device. You can update your router either using a manual method or directly through the setup.ampedwireless.com window. A user doesn’t need the availability of the Internet while updating the Amped router through a manual method.
marce1000
 - FYI : https://ampedwireless.com/support.html
           http://www.forums.ampedwireless.com/
  M.
