How do i configure guest wifi access using 2504 WLC with Fortigate UTM as L3 Device?
vashistsonu
Dear All
I have a 2504 Wireless Controller with multiple radios attached. I currently have a "private" WLAN configured (taking ip from windows server based DHCP of Range 192.1681.0/24 ) and working, but I need to add a Guest/Public WLAN which should take the IP from Other DHCP Configured on Fortigate UTM of range 172.16.0.0/24.
We have one SG300 switch in the office and the rest are basic switches.
Our firewall/router is a Fortigate UTM 240D
Find the attached network diagram for the issue.
Is there a SIMPLE way to enabling guest access that doesn't require VLANS (or are VLANS easier than I'm making them)?
Thanks.
0 Replies 0
