How do I write a eem script to catch high cpu on cat6k?
cchrysle
I have a high cpu condition I am trying to catch in a 6509 with a WS-SUP720-3B
running s72033-advipservicesk9_wan-mz.122-33.SXI2a  code.
I configured this eem script but even when this message is printed in the log, it doesn't execute.
*Jun 9 19:15:48.822: %HA_EM-6-LOG: cpu_stats: ------HIGH CPU DETECTED----, CPU: 92%
Am I missing a parameter on my trigger?
event manager applet cpu_stats
event syslog pattern "%HA_EM-6-LOG: cpu_stats: ------HIGH CPU DETECTED----" maxrun 120
action 1.02 cli command "enable"
action 1.03 cli command "show clock | append disk0:cpu_stats"
action 1.04 cli command "show proc cpu sort | append disk0:cpu_stats"
action 1.05 cli command "Show proc cpu history | append disk0:cpu_stats"
action 1.06 cli command "debug netdr cap rx"
action 1.07 cli command "show tcp brief | append disk0:cpu_stats"
action 1.08 cli command "show ibc | append disk0:cpu_stats"
action 1.09 cli command "show platform hardware capacity ibc | append disk0:cpu_stats"
action 1.15 cli command "show netdr cap | append disk0:cpu_stats"
action 1.16 cli command "undebug all"
This is from the show logg:
*Jun 9 19:23:44.066: %HA_EM-6-LOG: cpu_stats: ------HIGH CPU DETECTED----, CPU: 91%
*Jun 9 19:44:18.862: %SYS-5-CONFIG_I: Configured from console by console
*Jun 9 19:49:34.718: %HA_EM-6-LOG: cpu_stats: ------HIGH CPU DETECTED----, CPU: 91%
*Jun 9 19:50:58.962: %SYS-5-CONFIG_I: Configured from console by console
But the disk0:cpu_stats file never gets data appended to it.
Thank you in advance for any assistance,
Chris
Joe Clarke
I'm betting you need to do:
event manager session cli username USER
Where USER is a user authorized to execute all of these commands.  This assumes you have command authorization enabled.  If not, post the output of "debug event manager action cli".
Hi Joseph,
I have a continuous ping from a 4500 to this 6500.
I enabled the debug event manager action cli but got limited output.
So enabled debug event manager all.
Here is the output:
*Jun 10 15:30:20.673: cli_history_entry_add: free_hist_list size=0, hist_list size=7
*Jun 10 15:30:20.673: check_eem_cli_policy_handler: num_matches = 0, response_code = 1d
c6500#
*Jun 10 15:30:22.417: cli_history_entry_add: free_hist_list size=0, hist_list size=7
*Jun 10 15:30:22.417: check_eem_cli_policy_handler: command_string=end
*Jun 10 15:30:22.417: check_eem_cli_policy_handler: num_matches = 0, response_code = 1
*Jun 10 15:30:22.417: fh_fd_config_event_match: num_matches = 0
*Jun 10 15:30:22.417: fh_fd_config_event_notify:
*Jun 10 15:30:22.429: fh_fd_syslog_event_match: num_matches = 0
*Jun 10 15:30:22.429: fh_fd_data_syslog: num_matches = 0
*Jun 10 15:31:00.001: fh_fd_timer_process_async
*Jun 10 15:31:00.001: cron_tick: num_matches 0
*Jun 10 15:32:00.005: fh_fd_timer_process_async
*Jun 10 15:32:00.005: cron_tick: num_matches 0
*Jun 10 15:33:00.001: fh_fd_timer_process_async
*Jun 10 15:33:00.001: cron_tick: num_matches 0
c6500#debu event mana
*Jun 10 15:34:00.001: fh_fd_timer_process_async
*Jun 10 15:34:00.001: cron_tick: num_matches 0ger action cli
Debug EEM action cli debugging is on
c6500#
*Jun 10 15:34:08.181: cli_history_entry_add: free_hist_list size=0, hist_list size=7
*Jun 10 15:34:08.181: check_eem_cli_policy_handler: command_string=debug event manager action cli
*Jun 10 15:34:08.181: check_eem_cli_policy_handler: num_matches = 0, response_code = 1
*Jun 10 15:35:00.001: fh_fd_timer_process_async
*Jun 10 15:35:00.001: cron_tick: num_matches 0
*Jun 10 15:36:00.009: fh_fd_timer_process_async
*Jun 10 15:36:00.009: cron_tick: num_matches 0
*Jun 10 15:37:00.001: fh_fd_timer_process_async
*Jun 10 15:37:00.001: cron_tick: num_matches 0
*Jun 10 15:38:00.001: fh_fd_timer_process_async
*Jun 10 15:38:00.001: cron_tick: num_matches 0
C6500# sh proc cpu
CPU utilization for five seconds: 93%/11%; one minute: 91%; five minutes: 90%
PID Runtime(ms) Invoked uSecs 5Sec 1Min 5Min TTY Process
Thank you for your help,
Chris
Ah, sorry, I missed your event trigger.  EEM cannot match syslog messages that it generates.  Your applet here will never trigger.  Why not use "process cpu threshold ..." to enable a CPU threshold, then match on the CPURISINGTHRESHOLD pattern?
