How I do CLI template in Cisco Prime to enable SSH connection to devices?
cstcom
I need to enable ssh connection to devices, to do a CLI Template, i have a doubt if i can send "yes" and leght when generate rsa key.
How be the template to next commands?
conf t
Enter configuration commands, one per line.  End with CNTL/Z.
ROUTER(config)#ip domain-name domain.name
ROUTER(config)#crypto key generate rsa
% You already have RSA keys defined named ROUTER.domain.name.
% Do you really want to replace them? [yes/no]: yes
Choose the size of the key modulus in the range of 360 to 2048 for your
  General Purpose Keys. Choosing a key modulus greater than 512 may take
  a few minutes.
How many bits in the modulus [512]: 1024
% Generating 1024 bit RSA keys, keys will be non-exportable...[OK]
ROUTER(config)#ip ssh version 2
ROUTER(config)#ip ssh time-out 120
ROUTER(config)#ip ssh authentication-retries 3
ROUTER(config)#line vty 0 4
ROUTER(config-line)#transport input telnet ssh
ROUTER(config-line)#end
ROUTER#write
Building configuration...
[OK]
ROUTER#
Marvin Rhoads
You can do this using the interactive command feature. The User Guide even cites the specific example you are asking about when describing how this works:
Adding Interactive Commands
An interactive command contains the input that must be entered following the execution of a command.
To enter an interactive command in the CLI Content area, use the following syntax:
CLI Command<IQ>interactive question 1<R>command response 1 <IQ>interactive question 2<R>command response 2
where <IQ> and <R> tag are case-sensitive and must be entered as uppercase.
For example:
#INTERACTIVE
crypto key generate rsa general-keys <IQ>yes/no<R> no
#ENDS_INTERACTIVE
Source:
http://www.cisco.com/c/en/us/td/docs/net_mgmt/prime/infrastructure/3-0/user/guide/pi_ug/config-temp.html#47279
