How restauring a BD in CWLMS 2.2
expe_0626
Hi!
I want to know how I can do a restoring date base. I Do the following:
Server- admin- backup now.
I need to change the server machine. The backup was done. And now how I restauring the data?
Thanks!
best regards!
yjdabear
You'd want to used the "-force" option if the new server has a different hostname.
http://www.cisco.com/en/US/docs/net_mgmt/ciscoworks_resource_manager_essentials/3.5/user/guide/ug_appc.html
"restorebackup.pl
Restores an earlier backup of the database.
$NMSROOT/bin/perl restorebackup.pl [-force] [-s groupName] [-gen generationNumber] {-d backup directory}
This script can be used for user-specific requirements to:
•Restore only one group. For this, use the '-s groupName' parameter.
•Restore all groups. For this, do not use the '-s' parameter.
•Installed suites that includes Common Services and Essentials.
•See a list of the available backed-up generations. For this, enter the following at the command line:
$NMSROOT/bin/perl restorebackup.pl -h {-d backup directory}
