how to add a switch to acs for login and ads authentication
carl_townshend
Hi all
I want to add my switch so that it authenticates to my acs for login auth, I have done the switch end, using radius, also added the switch on the acs, how do I force the acs to use windows auth for this login?  do i just go under the network config where the device is and tick the box saying use windows database for authentication, and then do a group mapping ?
cheers
0 Replies 0
