04-28-2020 06:52 AM
I need to change the mgmt 0, mask, and default gateway on a Cisco 3132Q switch and want to make sure of the command structure. Will the change be effective immediately or will it require a reboot? I will be performing a copy run start after the change.
Solved! Go to Solution.
04-28-2020 09:54 AM
- These changes will take effect immediately. I would advise to make the change and check if it becomes available through the new network-parameter settings. I advise to check this first , ir it's available after the change, then afterwards save the config. Otherwise you could be locked out for 'eternity'. (meaning - if it doesn't work, in that case a reboot should still give access through the old-network parameters for mgmt0)
M.
04-28-2020 09:54 AM
M.
04-28-2020 10:10 AM
Thanks for the info!
I saw in a separate post the command list starting out in enabled mode:
conf t
interface mgmt 0
ip address 192.168.0.100/24
exit
vrf context management
no ip route 0.0.0.0/0 (old gateway information)
ip route 0.0.0.0/0 192.168.0.1
exit
copy run start
In the above situation I assigned 192.168.0.100 as the mgmt ip address of the VSM with gateway 192.168.0.1 and subnet mask corresponding to 255.255.255.0
I will be logging in locally through a serial connection so I can check remote access to the changed parameters before I reload.
