how to check default dscp map to tx queues on asr920
aljoush12
Hello Experts,
Can you tell me how to check the default dscp mapping to TX queues on ASR920? If you point me to a documentation, that would be great. I appreciate your help.
Thank you
Hi Balaji,
Thank you for sharing the document. This document doesn't provide the info about default dscp mapping to TX queues.
Thank you
Joseph W. Doherty
Usually Cisco routers, unlike Cisco switches with active QoS. do not have other than a single default egress queue, to which all traffic would be directed.
