How to check for SSH feature?
Hi @all,
does anyone know how to check all devices if they are ssh capable?
I already made a "Custom Report Template" in RME Inventory, with query "Image:Feature:contains:SSH" OR "Image:System Image File:contains:k9"
and that's OK for normal IOS Versions but not for the old ones, e.g. this doesnt work for IOS version like "c6sup2_rp-PK2SV-M"or "c2950-i6q4l2-mz"...
Is there a better query or option to check also the old version if they are ssh capable?
THX,
Thomas
Joe Clarke
Search the image name for the string "k9".  This means strong crypto support, and thus SSH will be available.
Whoops, I saw you were already using "k9".  Add "k2" and "k8" as well.
Joe Clarke
