how to choose Cisco Prime NCS
Dear Cisco Team,
I would like to know what are the main facts to choose Cisco Prime NCS.
And how many kind of monitoring system are there in Cisco.
Best Regards,
Thet Htar
AFROJ AHMAD
Hi Thet,
Cisco Prime Infrastructure simplifies the management of wireless and wired networks. It offers Day 0 and 1 provisioning, as well as Day N assurance from the branch to the data center. We call it One Management. With this single view and point of control, you can reap the benefits of One Management across both network and compute.
Prime Infrastructure enables you to configure and monitor one or more controllers, switches and associated access points. Prime Infrastructure includes the same configuration, performance monitoring, security, fault management, and accounting options used at the controller level and adds a graphical view of multiple controllers and managed access points.
Read the below link  for more detail::
http://www.cisco.com/c/en/us/td/docs/wireless/prime_infrastructure/1-2/configuration/guide/pi_12_cg/ovr.html
You can download it from here and use it under evaluation period for testing::
https://software.cisco.com/download/release.html?mdfid=286236028&flowid=72882&softwareid=284272932&release=2.2&relind=AVAILABLE&rellifecycle=&reltype=latest
Thanks-
Afroz
***Ratings Encourages Contributors ****
Thanks- Afroz [Do rate the useful post] ****Ratings Encourages Contributors ****
Hi Afroz,
Thanks you for your information.
Best Regards,
Thet Htar
