HOW TO CONFIGURE EEM NEXUS 3000 FOR WATCHDOG
Hi:
Please your help. I need configure EEM to get that every 10 minutes my nexus 3000 send a msg syslog with response of command "show environment"
It is possible???
If no, which is the alternative???
Tanks for your help.
sclake
Hi.
New to EEM and also have the same issue.  I don't see any timer option under the event configuration of the applet I need to create....
c1.t32(config-applet)# event ?
  cli             Create a cli event specification
  counter         Create a counter event
  fanabsent       Create fanabsent event specification
  fanbad          Create fanbad event specification
  memory          Create memory thresholds event specification
  oir             Create Online-Insertion-Removal event specification
  policy-default  Use the event in the system policy being overridden
  snmp            Create a 'snmp' event specification.
  storm-control   Create a storm control event specification
  syslog          Create a syslog event specification
  sysmgr          System manager related events
  temperature     Create temperature event specification
  track           Create a 'track' event specification
This is where we would configure a chron-type event, right?
Scott.
Joe Clarke
This is not possible on NX-OS.  You can, however, use the scheduler feature on NX-OS to schedule commands.  See http://www.cisco.com/c/en/us/td/docs/switches/datacenter/nexus3000/sw/system_mgmt/503_U3_1/b_Cisco_n3k_System_Mgmt_Config_503_U3_1/b_Cisco_n3k_System_Mgmt_Config_503_U3_1_chapter_010011.html for more details.
amitku6
event manager applet watchdog_eem
  event timer watchdog time 600 name watchdog
  action 1.1 syslog priority critical msg Syslog message for 10 minute watchdog
  action 1.1 cli show environment
  exit
