how to create a virtual interface to a vlan 10
sjo626
luis_cordova
Hola @sjo626 ,
Could you explain your doubt a little more?
Even a small diagram of your network could help.
Hi @sjo626 ,
If you are going to occupy vlan 10, it could be something like this:
R(config)# interface f0/X
R(config-if)#no shutdown
R(config-if)# interface f0/X.10
R(config-if)# encapsulation dot1q 10
R(config-if)# ip address <ip gateway vlan 10><mask>
You must make sure that the interface of the switch that connects to the router is in trunk mode
Then, you can occupy a routing protocol to connect the vlan 10 networks with the other networks
