How to delete backup.lock
jeeyishyuan
Hi Experts,
I have stop the daemon manager but I am still unable to delete the backup.lock.
Pls advise.
Thanks and Regards,
YS
The DEL /F command reports the same thing? If so, a backup process may still be running (backups are run out of Windows AT, not Daemon Manager). Check for any running Perl processes, and kill them. Then try and remove the lock file. If in doubt, reboot.
Joe Clarke
What error do you get trying to delete it? What if you use DEL /F from a DOS prompt?
Hi Joe,
The error shown Can't delete the file as it is used by another person or another process.
