How to delete devices in LMS 4.0?
jennyjohn
I had migrated from LMS 3.2 to LMS 4.0 successfully, but I have few devices which are no longer in the network and I want to remove them from LMS. I believe those devices were manually entered (not discovered) in LMS 3.2. How can I delete those devices?
I am planning to migrate all routers and switches from snmpv1/v2 to snmpv3 for sending traps to LMS. How can I make the snmp changes for these devices on LMS 4.0
Thanks in advance
vinodjad1234
Level 2
Level 2
If you have devices which are not in use as of now , you can deleted the same going to below option :
login to LMS 4.0
and Enter into , Inventory > Device Management > Add/delete devices
once you come above option , you can delete the deivices whicever you want .
