How to exceed 255 ip address
FMComputers
Hi @FMComputers ,
Yes.
In that case, the parameters would be as follows:
Network = 192.168.2.0/23
Range = 192.168.2.1 - 192.168.3.254
Broadcast = 192.168.3.255
If there are other devices with the IP parameters assigned statically, be sure to update the mask in these as well.
Remember to mark the correct answers as solved, because that helps other users with similar doubts.
5 Replies 5
luis_cordova
Hi @FMComputers ,
Could you be a little more specific about your problem?
If you mean to be able to address more than 255 devices, this can be achieved with a suitable mask for it.
With a mask /24 you can address up to 254 host
Network = 192.168.0.0
Host = 192.168.0.1 - 192.168.0.254
Broadcast = 192.168.0.255
With a mask /23 you can address up to 510 host
Host = 192.168.0.1 - 192.168.1.254
Boradcast = 192.168.1.255
How would you set this up in your router and in tcp/ipV4
Hi  @FMComputers ,
Assuming that your network is connected to the f0 / 0 interface and you want to give IP parameters to your network of more than 255 hosts by DHCP:
Router(config)#int f0/0
Router(config-if)#ip address 192.168.0.1 255.255.254.0 <-IP address network gateway(192.168.0.1/23)
Router(config-if)#no shutdown
%LINK-5-CHANGED: Interface FastEthernet0/0, changed state to up
Router(config-if)#ex
Router(config)#ip dhcp excluded-address 192.168.0.1 <-excludes the gateway of the pool DHCP
Router(config)#ip dhcp pool TEST <-create the DHCP pool
Router(dhcp-config)#network 192.168.0.0 255.255.254.0
Router(dhcp-config)#default-router 192.168.0.1
Now, the devices connected to this interface can obtain up to 510 different addresses for the hosts.
Can I keep my ip 192.168.2.0 and just change the Subnet to 255.255.254.0
Hi @FMComputers ,
Yes.
