04-30-2019 12:06 PM
throughout our MAN. Hello all and thanks for your time and expertise.
At this stage we have Kaspersky setup in one location. For those of you who don't know we're using Kasperksy as an imaging solution.
We want to have a centralized setup with Kaspersky in one buidling. And then if we are in other buildings we would RDP to the main server and be able to image in the other buildings.
I understand I may have to go to Kasperksy for this but I was wondering if you good folks could help me from a networking perspective.
Should this traffic be on a separate VLAN with QoS prioritizing traffic or is this a simple matter of IP helpers setup in the various buildings.
And I'm sure this route has to be setup as well.
Anyway, I appreciate any recommendations you have on this topic.
05-01-2019 01:17 AM
05-01-2019 06:35 AM
Mark,
Thanks for the information. Yes, we currently use Linux with PXE, same as you. Appreciate your help.
05-01-2019 07:31 AM
05-01-2019 07:39 AM
Mark,
It's also possible to deploy the Kaspersky Network agent on the dhcp servers in the respective buildings and then the IP helpers for those servers are already in place. Then the handoff is from the dhcp server to Kaspersky.
So if this works, or if we use the specific IP helper pointing to Kaspersky, do you think we need to get into any QoS or no? Just want to follow best practices. Again, appreciate your time.
05-01-2019 08:30 AM
05-01-2019 08:44 AM
Thank you Mark. I will test this out and follow-up. Much appreciated.
05-02-2019 06:34 AM
Mark,
I tested a device out and it connected no problem across the network. That said the actual performance relative to the imaging is terrible.
Please note we have 10GB interconnects between the buildings. Inside the building we have 1GB speed. The image was 22GB. I waited around for an hour and the image still wasn't completed. Do you have any recommendation or insight as to what could be slowing the imaging process down? Thanks.
05-02-2019 08:01 AM
05-02-2019 10:52 AM
Thanks Mark. We don't have instances of Kaspersky in all the buildings. We want to have a central sever and then be able to image over the network to our various buildings which I thought we could do with 10gb interconnects. I really don't want to get into installing a kaspersky server in every building. If I have to do that I'll go the USB route for the guys in the field. Kaspersky is just a pain in the butt to use. Amazingly Kaspersky doesn't even have a status indicator relative to the imaging process. One doesn't know how long the image will take.
And we were imaging after school so traffic was basically nothing.
05-02-2019 11:54 AM
05-02-2019 12:42 PM
05-02-2019 12:47 PM
Will do. Thanks Mark.
