How to find a MIB to a CLI Command?
Willem de Groot
Hi All
If I have a CLI SHOW Command to get some information from a switch/Router, how do I find the corresponding MIB File to this command?
Example:
I want to check the Reciever Power for a specific interface (in my case SPF in Gi1/1) the Interface is from type: DWDM-4851 SFP
#sh int gi 1/1 transceiver detail
ITU Channel 36 (1548.51 nm),
Transceiver is internally calibrated.
mA: milliamperes, dBm: decibels (milliwatts), NA or N/A: not applicable.
++ : high alarm, +  : high warning, -  : low warning, -- : low alarm.
A2D readouts (if they differ), are reported in parentheses.
The threshold values are calibrated.
                              High Alarm  High Warn  Low Warn   Low Alarm
          Temperature         Threshold   Threshold  Threshold  Threshold
Port       (Celsius)          (Celsius)   (Celsius)  (Celsius)  (Celsius)
Gi1/1       33.3               100.0        95.0        -5.0      -10.0
           Voltage            Threshold   Threshold  Threshold  Threshold
Port       (Volts)            (Volts)     (Volts)    (Volts)    (Volts)
Gi1/1      3.25                  3.59        3.50        3.09       3.00
           Optical            High Alarm  High Warn  Low Warn   Low Alarm
           Transmit Power     Threshold   Threshold  Threshold  Threshold
Port       (dBm)              (dBm)       (dBm)      (dBm)      (dBm)
Gi1/1        1.9                 5.0         4.0         0.0       -1.0
           Receive Power      Threshold   Threshold  Threshold  Threshold
Gi1/1     -11.5                -2.0        -3.0       -33.0      -40.0
sh inv
NAME: "1", DESCR: "WS-C3560X-24"
PID: WS-C3560X-24T-L   , VID: V01  , SN: FDO1417P0HG
NAME: "Power Supply 0", DESCR: "FRU Power Supply"
PID: C3KX-PWR-350WAC   , VID: V01  , SN: LIT14140QKF
NAME: "FRULink Slot 1 - FRULink Module", DESCR: "FRULink 1G Module"
PID: C3KX-NM-1G        , VID: V01  , SN: FDO14340KT9
NAME: "GigabitEthernet1/1", DESCR: "DWDM-4851 SFP"
PID:                     , VID:      , SN: FR10080004
NAME: "GigabitEthernet1/2", DESCR: "DWDM-4851 SFP"
PID:                     , VID:      , SN: FR10080005
Willem
I believe you should get this using
entitySensorMIB
http://tools.cisco.com/Support/SNMP/do/BrowseOID.do?local=en&translate=Translate&objectInput=1.3.6.1.4.1.9.9.91
this OIDs should give you the exact value..
entSensorValueEntry
yjdabear
If nothing else, one could always let "snmpwalk" loose and look through the mass of returned output for possible candidate(s).
entitySensorMIB
entSensorValueEntry
Brahadesh Srinivasaraghavan
Thanks for the Answer, this seems to be the right counter.
I can not found the interface description in the SNMP Walk but checking the SNMP walk results against the show results, this must be the same.
Can you tell me how you found this SNMP OID?
Willem
I have seen this come up before
Brahadesh
