How to get automated email when IP connection is lost?
juergenbaumann
An IP connection to one of my IP cameras went down - as it turned out, the ethernet cable was unplugged (PoE). Unfortunately this remained unnoticed for some time.
Is there an option in a RV320 router, or SB300 switch to get an automated email, when a IP connection goes down? Where to find this in the device and how to configure?
Thanks, Juergen
Mark Elsen
 -  Usually for Cisco devices you have (sys)-logging and snmp trap functionality; for the latter an accompanying trap handler could achieve this functionality.
  M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
Mark Elsen
  M.
       Beauty and terror
      Just keep going
       No feeling is final
Hi, thanks for pointing me in the right direction. Could not work out everything so far, but time will do :)
Thx
