High CPU utilization
Nub65
Level 2
Level 2
We are experiencing high CPU utilization on WS-C3650-24TS switch.
Can anyone help me identify the problem?
I reloaded the stack and it helped.
10 Replies 10
balaji.bandi
Not sure what is the version of code running here. show version should give you information :
i see some bug here, worth checking :
https://quickview.cloudapps.cisco.com/quickview/bug/CSCux39490
BB
Version 03.03.05SE
Leo Laohoo
Raise a TAC Case.
This is a very popular bug: CSCuo14511
I was thinking about restarting stack, maybe it can help?
Uptime of the stack is about 3 years.
yes, reload the device may fix if this the high CPU occurs again recommend to upgrade as per the Bug reported recommend version to fix..
BB
If I just type "reload" it will reload all the switches in the stack right?
yes, it will reload entire stack, that is your intention.
BB
Thank you
Glad all end good, Hope it is resolved, mark as resolved.
BB
