04-16-2007 08:15 AM
not-accessible
Size list: 1: 0..2147483647
Description: Index into cardTable (not physical chassis
slot number, matches cisco chassis MIB cardindex)
any workaround for this?
04-16-2007 08:35 AM
You need to read this value from the left-hand side of the OID name/value pair. So, if you do a GETNEXT operation on cipCardEntry, the last element returned in the resulting varbind will be the index.
04-22-2007 06:19 AM
Thanks, but the format of indexes seems different from those shown in cmd 'show extended channel x/y statistics' as
csna path xxyy, while by snmp polling the result is x.y.z.
If we need the xxyy directly from snmpget, any suggestion?
04-22-2007 07:01 AM
The cipCardEntryIndex is not supposed to be the same as the actual physical slot number. Instead, it is an index into the OLD-CISCO-CHASSIS-MIB, and will match cardIndex for this card. That will allow you to map the current channel card back to a chassis card.
