How to get/monitor the PTP offset from master on Nexus using SNMP
I'm trying to find an OID that I can use to monitor the ptp clock offset from the master. For clarification: on a switch I execute the command "sh ptp clock" and it gives me the integer value of the "Offset From Master" and so I need an OID that can give me this data to poll for monitoring purposes. Also executing "sh ptp corrections" will give me the offsets for every second. I would like to know of OIDs that exist for this offset from master and for other PTP information. I have nexus switch equipment and using SNMPv3. Please reply if you know of any information or if it even exists.
Anything helps. Thanks!
Mark Elsen
                 - Check this MIB and or any of the mentioned variables can be useful :
                           https://iphostmonitor.com/mib/CISCO-PTP-MIB.html
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
