How to get SNMP OIDs on CBS 350??
namlh
May I know what OIDs or metrics can cisco cbs350 support SNMP protocol??? I want to monitor my device's CPU and RAM via SNMP protocol
5 Replies 5
I seen link check below but i can't see OIDs of CPU and RAM switch cisco
i may be not clear, download the MIB and check if that can be helpfull for your needs.
as per the information  below OID should get what you looking for  Most of the cisco models
ciscoMemoryPoolUsed : .1.3.6.1.4.1.9.9.48.1.1.1.5
ciscoMemoryPoolFree : .1.3.6.1.4.1.9.9.48.1.1.1.6
CPU - 1.3.6.1.4.1.9.6.1.101.1.9.0
BB
Hi bro, I tried your OIDs but they don't seem to work, error SNMPv2-SMI::enterprises.9.9.48.1.1.1.6 = No Such Object available on this agent at this OID
My Switch is CBS 350 and CBS 220, can you support me??
as i mentioned download MIB and add to your SNMP
download MIB for you to get that metrics :
https://software.cisco.com/download/home/286325995/type/283415684/release/3.2.0.84
still issue contact SMB TAC.
BB
