09-02-2005 05:59 AM
Hi all,
we have a lot of different Cisco Switches and we want now to display the Traffic of some VLANs (at a Webpage). I would like to get the Traffic with SNMP (using Mrtg).
For Example:
Lets say we have a Switch with 24 Ports. 12 Ports are used with VLAN 100 and the other 12 Ports are used with VLAN 200.
The Problem:
Sure i can Mrtg say: "Take the physical Ports 1,2,3,4,5...12 ,build a sum and display it as VLAN 100". But if the configuration of the Switch changes i have always to modify the mrtg Config too.
My Question:
Does a Cisco Switch store some VLAN Information like Traffic/Bandwidth etc in a special part of the MIB? If so, i could directly read out these values and display it without having problems when the configuration of the Switch changes.
(I know that the Cisco Switches produces an "interface - entry" for every VLAN, but i did not find something about the Traffic)
Thanks a lot
09-03-2005 04:08 PM
I am using MRTG to grap Vlan traffic and i am doing it from the interfaces from the router that is routing that vlan, not from the switch interfaces. Also i have a dedicated server switch that i monitor the physical interfaces there as well. This way we can keep check on the sysadmins as to when backups are running.
09-03-2005 08:27 PM
I had experience to plot traffic of a vlan interface on a 2950T but i remember that it plotted just controling traffic like BPDU or something like that and it didn't plot real traffic that is passed from/to VLAN.
