how to implement the ethernet port speed limit in cisco N9K-C9372TX-E
Hi Experts,
i have switch with Model number is N9K-C9372TX-E & NXOS: version 7.0(3)I5(2).
May i know the Command to implement the ethernet port speed limit to 25 Mbps on ingress to port or Egress out in the switch?
thanks.
5 Replies 5
@luis_cordova yes, i verifed this link but unfortunately this link provides only bandwidth as an informational-only.
basically i would like to apply QoS kind off to limit the bandwidth on the ethernet port. could you help me?
You don't want QoS, you want Shaping. Not sure if the Nexus can do that, as it's generally a bad idea.
@patoberli oo. Nexus cannot? how do i confirm this?
Yes, basically i would like to limit the bandwidth on this ingress to the port with 25 Mbps.
Download the manual and search for the word shaping. If you don't find it, it's possible that the Nexus can't do that. Maybe there are also other variants, but I only know of the old version of shaping.
