How to monitor gbic SFPs metrics using SNMP?
Go2theftree
i have
Vendor Name           :   CISCO-FINISAR
Vendor Part Number    :   FTRJ1319P1BTL-C
Vendor Revision       :   0x42 0x20 0x20 0x20
and when i try to get info from telnet i get normal information
#sho interfaces transceiver
If device is externally calibrated, only calibrated values are printed.
++ : high alarm, +  : high warning, -  : low warning, -- : low alarm.
NA or N/A: not applicable, Tx: transmit, Rx: receive.
mA: milliamperes, dBm: decibels (milliwatts).
                                           Optical   Optical
           Temperature  Voltage  Current   Tx Power  Rx Power
Port       (Celsius)    (Volts)  (mA)      (dBm)     (dBm)
Gi0/26       52.5       3.25      26.9      -5.7     -13.8
but i couldnot get from snmp can someone tell me if is some configure in device or  oid .
0 Replies 0
