How to mornitor VSS (Virtual Switching System) & Stack (Switch) By Cisco Prime Infrastructure
Dear all,
I have 02 C6504-E with VSS (Virtual Switching System)
   and 02 C3750X-24T-L used Stack
How to you Cisco Prime Infrastructure to monitor VSS & Stack tatus?
Thanks.
5 Replies 5
Noone?
Up
It doesn't do this.
Thank you.
Could PI 2.0 do it.
And do you know any Cisco previous products can do it?
aqjaved
Level 3
Level 3
Virtual Switching technology is  the process of combining two standalone distribution switches found in  the local distribution layer into a single management point.
The Virtual  Switching System functions and appears as a single switch to the wiring  closet and the core layer. You can also create Virtual Switching Systems  with a pair of standalone switches available in the core layer.
For configuration please check  the below link:
http://www.cisco.com/en/US/docs/net_mgmt/ciscoworks_lan_management_solution/4.1/user/guide/configuration/configvss.html#wp1042960
