how to netflow
blue4cisco
We hv a cisco switch 3560, I want to configure netflow on a particular interface like tunnel 3, Plz. guide me how can i achive it. Note: plz. tell commands by command.
royalblues
Level 10
Level 10
Hi friend,
You can use the following commands
interface tunnel 3
ip route-cache flow
ip flow-export destination
ip flow export version
The ip addres will be the server ip address and the port wil be the port the application is listening to for netflow packets
HTH, rate if it does
Narayan
I want only netflow of tunnel interface not any other what i do for it...
Jan Nejman
Level 3
Level 3
netflow is not supported on the 3500 or 3700 series. It is possible to configure it, but you never receive netflow exports...
For more information about netflow see web page: http://netflow.caligare.com
Bye.
Jan
