How to put Z3s into a subgroup?
Kaz769
Greetings community people,
I was wondering if there is a way to put a group of Z3s under their own subgroup rather than having to list every single one under a admin's authority. There are too many to list and the UI wigs out so instead I'd like to create a subgroup of them and then distribute the subgroup authority to our admins who need it. Is there anyway to do that?
Thank you for your time and input.
5 Replies 5
marce1000
           - What are 'Z3s' ?
 M.
Cisco-Meraki Z3, teleworker gateway in a cisco-meraki based network.
They allow users to spoke from home to onsite network resources and thus create their own individual network objects for each one deployed. You can see how that would get a bit difficult to doll out privs for after about a dozen or so.
They are cisco devices, is this not the right place to ask?
               - You may ask this question here -> https://community.meraki.com/
  M.
The original post asks "They are cisco devices, is this not the right place to ask?". Yes they are Cisco devices and in some sense it is legitimate to ask in a Cisco community about them. But given how many of us had no idea what a Z3 was, it is pretty clear that the suggestion from @marce1000 will direct you to a place where you are more likely to get good responses.
It is not that this place is wrong but that the other place is much better.
Rick
Kaz769
Okay, thank you.
