how to reload switches using cisco prime infrastructure
saud43210
hi,
how to reload switches using cisco prime infrastructure 3
5 Replies 5
Marvin Rhoads
Make a cli template and deploy it to the target devices.
A cli template will always be in configuration mode so you would use something like:
do copy run start
do reload
thank you for reply. but this template didn't worked.
Can you share the error log?
found it, i should use interactive in template
#MODE_ENABLE
#INTERACTIVE
commands<IQ>interactive question<R>response
#ENDS_INTERACTIVE
#MODE_END_ENABLE
Ah yes. Thanks for pointing that out. Since 'reload' requires the operator to confirm we need to do that.
