How to remove devices in " Devices Not Configured in ACS"
thongams2000
I have ciscoworks LMS 3.2 which is integrated with ACS. I am trying to find a way to edit or remove the devices in CS " Devices Not Configured in ACS". Need help !
Soniya
Marvin Rhoads
A number of folks have come across this same problem and a resolution method was posted a while back in this thread. Please see if that works for you.
Regards.
Vinod Arya
Ideally the solution for this issue is to add those device which comes under Devices Not Configured in ACS in ACS as a AAA client under any group.
Device missing in ACS server come in this category after ACS is integrated to LMS.
Also, you should check if the ACS is properly integrated with NMSROOT/bin/perl  NMSROOT/bin/ACSTestTool.pl.
-Thanks
-Thanks Vinod **Rating Encourages contributors, and its really free. **
