how to remove pxe boot settings. cisco 1841
jwilliams
A while ago I set up a pxe server and somehow eventually configured our Cisco router which ran our dhcp server as well.  We've removed the pxe boot server and now I'd like to remove those entries.  Essentially the two lines I believe I need to remove are here under my running-config:
   bootfile pxelinux.0
   next-server 10.100.100.230
found here:
ip dhcp pool dhcp
   network 10.100.100.0 255.255.255.0
   bootfile pxelinux.0
   dns-server 10.100.100.4
I've tried using the commands:
main-rt(config)#no bootfile pxelinux.0
main-rt(config)#no next-server 10.100.100.230
but those give errors
% Invalid input detected at '^' marker.
any ideas on how to get rid of these 2 lines?  Thanks
First you have to enter in dhcp-config mode:
main-rt(config)# ip dhcp pool dhcp
main-rt(dhcp-config)# no bootfile pxelinux.0
main-rt(dhcp-config)# no next-server 10.100.100.230
