How to see crypto certificate in running-config
AllezLom63194
Hi the community,
I have 2 ASR1001-X withe the same IOS version and the two have
crypto pki trustpoint TP-self-signed-XXXXXXX
and
crypto pki certificate chain TP-self-signed-XXXX.
When I do a sh run on the first-one I can see the crypto pki certificate in hexa format but not on the second one.
What ise the way to see it ?
For exemple:
crypto pki certificate chain TP-self-signed-396455978
certificate self-signed 01
3082032E 30820216 A0030201 02020101 300D0609 2A864886 F70D0101 05050030
30312E30 2C060355 04031325 494F532D 53656C66 2D536967 6E65642D 43657274
69666963 6174652D 33393634 35353937 38301E17 0D313931 32313830 38333135
Thank in advance.
6 Replies 6
Muhammad Zahid
To display the RSA public keys of your router/firewall, use the show crypto key mypubkey rsa command in privileged EXEC mode.
Please Rate Posts (by clicking on Star) and/or Mark Solutions as Accepted, when applies
Thank you for your response but it is not what I need.
In fact this commande show another certificats.
I juste want to see the certificat chain like on the first router when I do a show running-config.
Regards.
Muhammad Zahid
If "show running-config | begin crypto" doesn't show any self-signed certificate then it mean certificate is not available on that device, try adding a new self-signed certificate and see either it is reflecting in your running configuration.
You can generate self-signed certificate using this setup of commands.
ip domain name ccie.study.com
ip http secure-server
Hi Muhammad,
When I issue the commande I've got a fail message as you can see below
RTR-DC-01(config)#ip http secure-server
Failed to generate persistent self-signed certificate.
Secure server will use temporary self-signed certificate.
The problem is certainly here. Now I have to to find why.
Regards.
Do you have updated IOS?
There are some know bugs in old IOS; give it a try after update IOS
Reference:
https://www.cisco.com/c/en/us/support/docs/security-vpn/public-key-infrastructure-pki/215118-ios-self-signed-certificate-expiration-o.html
Muhammad,
You're maybe right but I have the same router with the same IOS that show me the certificat chain I don't think that the IOS version is my problem cause.
I'm in the 16.06.07 IOS version. Tha last version suggested by cisco
Regards.
