How to send a reload command using Cisco configuration engine?
avinashmahanty
All,
I have a Cisco Configuration engine that we use to send out configuration updates to our fleet of field routers? Although most of the other commands work via update config feature except for the reload command.
I need to send a reload command in order to have the field routers reload/restart but as it turns out sending the simple "reload" key word does not work.
i have tired different options but hasn't worked for me, some options that i have tried are
- reload
- reload <cr>
- reload <R>
- reload in 1
Any ideas?
Thx,
Avi
tjsanders
In CW2K it is under: Netconfig/Task Selector/General/
