EEM syslog filters
nawas
Level 4
Level 4
Is there a tcl script or EEM configuration where I can filter syslog messages from my switch to syslog server. My syslog server is filling with the 802.1x logs and I want to filter these if possile. I have Cisco 4507s with SUP6 and SUP7  using 151-1.
Dec 17 08:48:31.027: %AUTHMGR-5-SUCCESS: Authorization succeeded for client (xxxx.xxxx.xxxx) on Interface Gi1/21 AuditSessionID 0A04CD080000CD54FAFE6110
Dec 17 08:48:57.672: %DOT1X-5-SUCCESS: Authentication successful for client (yyyy.yyyy.yyyy) on Interface Gi2/13 AuditSessionID 0A04CD080000BCA3CA77D79F
Dec 17 08:48:57.672: %AUTHMGR-7-RESULT: Authentication result 'success' from 'dot1x' for client (xxxx.xxxx.xxxx) on Interface Gi2/13 AuditSessionID 0A04CD080000BCA3CA77D79F
Dec 17 08:48:58.676: %AUTHMGR-5-SUCCESS: Authorization succeeded for client (xxxx.xxxx.xxxx) on Interface Gi2/13 AuditSessionID 0A04CD080000BCA3CA77D79F
Joe Clarke
I'm not sure if logging discriminators are supported in your version of code, but that would be the easiest way to do this:
logging discriminator nodot1x severity drops 5,7 facility drops AUTHMGR mnemonics drops SUCCESS|RESULT
logging host 10.10.10.10 discriminator nodot1x
