How to set log level to trace for Confd netconfTraceLog, netconfLog?
bhuvan1
Developer logs can be set to trace level by adding the following line, as documented in ConfD User guide.
<developerLogLevel>trace</developerLogLevel>
Is it possible to set log level to trace for the other logs such as netconfTraceLog, netconfLog & auditLog?
The reason for looking for trace log level is that after sending a Netconf Hello message, I want to check whether it has reached the ConfD and what is ConfD response.
0 Replies 0
