01-22-2015 10:24 AM
Has anyone upgraded to Prime 2.2 in a appliance form 2.0.
01-22-2015 12:12 PM
I performed an upgrade last night from version 2.1 to 2.2
You have to backup the application, rebuild the appliance from scratch to version 2.2 from a DVD and then restore the application backup.
From start to finish the process took just over 8 hours.
Hope this helps
01-22-2015 12:15 PM
Thats great richard...i have a brand new appliance so i can play around is there any link which says about the procedure involved..i did search but most of them talk about virtual systems.
01-22-2015 12:34 PM
If you are building it from scratch it is very straight forward. The process is the same as a virtual system but in this case you need to boot the physical appliance from the DVD.
The quick guide lists the steps that you need to follow to initially configure the appliance, the steps are the same for a physical appliance as well as a Virtual.
01-22-2015 12:48 PM
alright let me burn the .iso PI 2.2 on the dvd was there any license rehosting issue involved..i read there will not be any isses with rehosting...
In my case its a new box but ive already installed the PAK on 2.0 and i think the upgrade procedure counts only when youre migrating from 2.1 or 1.4 or else its a direct installation from 2.0.
01-22-2015 12:58 PM
AS far as I'm aware sa long as you are going to restore an application backup from a 2.1 appliance where you are going to use the same IP address and hostname I don't think there will be an issue.
My licenses came across with the application restore.
If you are going to do it on a new box with different IP and hostname you may have to rehome the license.
01-22-2015 01:07 PM
Then i have to rehost the license anyway if iam upgrading from 2.0 to 2.1 or directly from 2.0 to 2.2 isnt it...
01-22-2015 01:33 PM
01-27-2015 07:17 AM
Hi Murphy,
Since it was a greenfield and i ididnt have much to loose though i had installed the license on PI 2.0 ....i went for a direct upgrade to PI 2.2 once on the GUI .. it was prompting for a 60 day period validity but since i had the copy of the license from cisco licensing i re-installed it on PI 2.2 ..it worked fine.
Thanks for taking your valuable time to reply ..
02-10-2015 08:42 PM
Hi Richard,
how to take the backup from prime local disk. 2.1 for upgrading to 2.2
02-11-2015 01:39 AM
You will need to setup a remote repository to copy the backup file to.
02-11-2015 01:58 AM
currently we are running with prime 2.1 , in back round tasks I don't find an option for creating external repository
02-11-2015 05:48 AM
Betha,
Please refer to the PI 2.1 Admin Guide. IT explains how to create a remote repository and backup your PI 2.1 from the command line interface.
01-28-2015 06:56 AM
Just as a reference for anyone else who might be reading this thread, I upgraded our 1.3 appliance to 2.2 yesterday, and everything worked perfectly. Here was the process I used;
It went smooth, the entire process took about 2 hours.
02-26-2015 10:12 AM
I need to make the very same upgrade like yours, from PI 1.3 to PI 2.2 running in HA using the existing appliances generation 1. The licence is for 500 devices.
I could not locate the pi212_20141118_01 patch.
Can you point me where to find this patch?
Thanks in advance
Robson
