How to use event parameters?
Aleksandr Serov
I've made simple eem applet for shutdown the port which trigered storm control event.
It is look like that:
event manager applet shut-storm
  event storm-control
  action 1.0 cli local python bootflash:shut-storm.py
and the script is
from cisco import CLI
from cisco import cli
import sys
import datetime
import time
import re
whitelist = [
"Ethernet1/1",
"Ethernet1/2"]
shlog = CLI('sh logg last 100 | i ETHPORT-5-STORM_CONTROL_ABOVE_THRESHOLD | last 3',False).get_output()
pat = re.compile(r'(\d{4} \w{3} \d{2} \d\d:\d\d:\d\d) \S+ \%ETHPORT-5-STORM_CONTROL_ABOVE_THRESHOLD: Traffic in port (Eth\S+|[Pp]o\S+)')
now = datetime.datetime.now()
delta = datetime.timedelta(seconds=180)
for l in shlog:
  mobj = pat.match(l)
  if mobj:
    port       = mobj.group(2)
    logTimeStr = mobj.group(1)
    logTimeObj = time.strptime(logTimeStr, "%Y %b %d %H:%M:%S")
    logTime    = datetime.datetime(*logTimeObj[:6])
    if now-logTime < delta:
      if port not in whitelist:
        cli("conf t")
        cli("interface %s" % port)
        cli("shutdown")
But the python script is a bit complecs because it shoud find triggered interfece in log.
Is it possible to use event parameters? And how?
I know that they are:
sw1# sh event manager history events det
Event ID Time of Event        Event Type                   Slot       Policies
32       09/30/2013 15:40:51  storm_control                active(1)  shut-storm
    interface = "Ethernet1/16", cause = "storm-control"
Joe Clarke
You should be able to do:
cli local python bootflash:shut-storm.py $interface $cause
However, calling Python scripts from EEM applets on Nexus is not officially supported yet, so your mileage may vary.
Joe Clarke
Thank you Joseph.
It works.
Now the applet looks like:
event manager applet shut-storm2
  event storm-control
  action 1.0 cli local python bootflash:shut-storm2.py $interface
And the script:
from syslog import syslog
import sys
whitelist = [
"Ethernet1/1",
"Ethernet1/2"]
port = sys.argv[1]
  cli("conf t")
  cli("shutdown")
  syslog(2, "Interface %s was shutdown due to storm conditions" % port)
