HUM UPMDb won't start
Since we ran out of disk space HUM isn't working.
Disk was freed, but things wren't running right so did a net stop crmdmgtd which never completed.
In the end had to do a reboot. Have tried stop/start crmdmgtd but the UPM processes won't start.
Can't seem to find a log that gives any clues. pdshow attached
Is there a lock somewhere that needs to be cleaned?
Joe Clarke
The best you can hope for is that the database transaction log has become corrupt. To check this, shutdown dmgtd, then look at NMSROOT\databases\upm. If you see a upm.log in there, delete it (del /f/q upm.log). Then, run:
NMSROOT\objects\db\win32\dbsrv9 -f NMSROOT\databases\upm\upm.db
Then restart dmgtd, and the UPM database engine and monitor should start. If not, then the upm database is most likely corrupt, and will have to be restored from a known good backup, or reinitialized. To reinit, run:
NMSROOT\bin\perl NMSROOT\bin\dbRestoreOrig.pl dsn=upm dmprefix=UPM
Joe Clarke
thanks, I'll give it a try. We're running in eval so data loss not too much of a problem
Success. After shutting down, removing upm.log then running dbsrv9 -f as suggested, all seems good again. Thanks
