I got locked out of my switch
acokoqiz
I am currently practicing on cisco packet tracer, so I used the command "enable password 5 cisco" then I leave the global configuration mode to the user mode and try to go to privilege's mode using the enable command, and I am prompted for a password which I set but when I type in 'cisco' as I earlier set. I keep getting bad secret message
How do I go about this or did I set the password wrong ?
6 Replies 6
Seb Rupik
Hi there,
You have a typo in your configuration. enable password does not take a privilege level, as I assume that is what you intended the '5' to mean. As such the enable password has been set to '5 cisco' .
cheers,
Seb.
R Manjunatha
Level 3
Level 3
the password which you used that is " 5 cisco "
please type as follow.
Switch>en
Password:5 cisco
Switch#
regards,
if you config AAA for enable, you need to add local at end and try many time before it success.
try this way
Martin L
Are you talking about this "<0-9> Encryption types not explicitly specified" option listed in  enable password ?  ?
dist-rtr01(config)#enable password ?
0 Specifies an UNENCRYPTED password will follow
7 Specifies a HIDDEN password will follow
PT should give you an error "Invalid encryption type: 5"  as it is just a simulator; it does not work or behave the same as real IOS. But, it will work (or should) when you type in enable password 7 05080F1C2243 (where 05080F1C2243 represents encrypted word of cisco)
dist-rtr01(config)#
dist-rtr01(config)#enable password 7 05080F1C2243
WARNING: Command has been added to the configuration using a type 7 password. However, type 7 passwords will soon be deprecated. Migrate to a supported password type
dist-rtr01(config)#
LINE The UNENCRYPTED (cleartext) 'enable' password
level Set exec level password
dist-rtr01(config)#enable password 5 cisco
dist-rtr01(config)#
You should read CCNA book for explanation of access, but CIsco doc page has also explanation see
https://www.cisco.com/c/en/us/td/docs/ios-xml/ios/security/d1/sec-d1-cr-book/sec-cr-e1.html#wp3884449514
Remember: with PT always use ? to see your options. PT is just a simulator, not real IOS
Regards, ML
**Please Rate All Helpful Responses **
btw. above output is from CML     Cisco IOS XE Software, Version 17.03.02
Cisco IOS Software [Amsterdam], Virtual XE Software (X86_64_LINUX_IOSD-UNIVERSALK9-M), Version 17.3.2, RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2020 by Cisco Systems, Inc.
Compiled Sat 31-Oct-20 13:16 by mcpre
siskum
Hello!
Your enable password is "5 cisco" you have to type as below, so simple.
Router>enable
Password: 5 cisco
Router#
Router#sh run
hostname Router
Router#conf t
Router(config)#
Router(config)#
Pls thumbs up, and press sloved problem. It will help for others too.
Best regards/Mallawar
Sisira
