Configured VLAN on interface but not not getting DHCP to assign IP
JWHolm81891
So, I didn't think this was going to be a big issue, assign the VLAN 66 which is used all over in our network to this port and wa-la, it's good to go. But....no. The switch is part of a stackable (3) 9200L, it's not going out anywhere, the interface goes just to a wall port, but even it it were, VLAN 66 is on the trunk port as well.
switchport trunk allowed vlan 3,10,11,31,50,66,72,95,100,137-151,201,209,210
Switch int config:
interface GigabitEthernet3/0/27
description camera
switchport access vlan 66
switchport mode access
switchport voice vlan 238
spanning-tree portfast
#sh vlan id 66
66 PSN-Cameras active Gi1/0/25, Gi1/0/26, Gi1/0/27, Gi3/0/27
If you need more info, please tell me what you need.
I'm seeing APIPA and not DHCP for some reason. Any ideas on why this would be?
we need more elaborate
run CDP to make SW detect if device is Phone or PC.
IP_Cartel
Do a sh run int vl 66
do you have an ip helper-address DHCPServer_IP
