I have assigned to implement Cisco work LMS3.2 for monitoring network devices such as C6509, C4507.
I try to used MIB from CISCO-ENVMON-MIB.my to generate Devices Voltage Report by create template poller.
![voltage001.jpg](/legacyfs/online/legacy/2/7/2/153272-voltage001.jpg)
then create a poller
![voltage002.jpg](/legacyfs/online/legacy/3/7/2/153273-voltage002.jpg)
after that I saw a pop up error
I check in RME Device that how many SNMP time out configured, all is 15 second.
I try incresing SNMP time out to 60 second and create Voltage Poller again but can't solve the problem.
Do I wrong?
Do I have other choice to generate Voltage Monitoring Report, Pls.
Note: All devices have been enable snmp trap energywise and reachable
Thank you.
