i'm going crazy
questit.srl
Hi all
I have the followin problem and after days of trials , now I don't know anymore what to do...
Our network structure is the following (I hope it is clear):
ISP ----[via RF Bridge]------ (aaa.bbb.ccc.138)  Router_WanToWiFi (192.168.1.1) ------[via wifi FOOWIFI]------ (192.168.1.254) AP_InClientMode -------- (192.168.1.253)  Router_CISCO881W-GN-E-K9  (10.0.0.1) ----[VLAN (10.0.0.0)]--- Business PCs and Printers
The router Cisco881W is configured for routing from inside 10.0.0.0 to outside 192.168.1.1 with static route 0.0.0.0 0.0.0.0 192.168.1.1.. however the
networking results very slow and many times the internet access is missing. More precisely, at startup the navigation is ok but after some minutes, it becomes unusable (it seems as a loop exist that generates flooding, but it is an idea).
After several trials, we noted that if we connect our PCs/Notebook to the FOOWIFI wlan and remove the CISCO881W router, the navigation is ok and very fast. When reattach the router, the problem come up again.
I have carefully cheked the router configuration and now I have no more idea of what to do...
This is our Cisco881W configuration with private info removed (I used [ ] to outline where removed info):
Router#show run
Building configuration...
Current configuration : 7085 bytes
! Last configuration change at 08:45:48 UTC Wed Jun 26 2013
version 15.1
no service pad
hostname Router
boot-start-marker
boot-end-marker
logging buffered 51200 warnings
no aaa new-model
memory-size iomem 10
crypto pki trustpoint TP-self-signed-1382020822
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-1382020822
revocation-check none
rsakeypair TP-self-signed-1382020822
crypto pki certificate chain TP-self-signed-1382020822
certificate self-signed 01
  [bla bla bla]
            quit
ip source-route
ip dhcp excluded-address 10.0.0.1
ip dhcp excluded-address 10.0.0.1 10.0.0.99
ip dhcp pool DHCP
import all
network 10.0.0.0 255.0.0.0
default-router 10.0.0.1
dns-server 10.0.0.1
domain-name [blabla].com
lease 0 10
ip cef
ip domain name [blabla].com
ip host router.[blabla].com 10.0.0.1
ip host samsungML3050.[blabla].com 10.0.0.91
ip name-server 192.168.1.1
no ipv6 cef
vpdn enable
vpdn-group 1
! Default PPTP VPDN group
accept-dialin
  protocol pptp
  virtual-template 1
l2tp tunnel timeout no-session 15
license udi pid CISCO881W-GN-E-K9 sn [MySerial]
username [myuser] password 0 [mypass]
class-map match-all CLASSMAP
match access-group 1
policy-map POLICYMAP
class CLASSMAP
interface FastEthernet0
no ip address
interface FastEthernet1
no ip address
interface FastEthernet2
no ip address
interface FastEthernet3
no ip address
interface FastEthernet4
ip address 192.168.1.253 255.255.255.0
ip nat outside
ip virtual-reassembly in
duplex auto
speed auto
interface Virtual-Template1
ip unnumbered Vlan1
ip nat inside
peer default ip address dhcp-pool DHCP
no keepalive
ppp encrypt mppe 128
ppp authentication ms-chap ms-chap-v2
interface wlan-ap0
description Service module interface to manage the embedded AP
ip unnumbered Vlan1
ip nat inside
arp timeout 0
interface Wlan-GigabitEthernet0
description Internal switch interface connecting to the embedded AP
no ip address
interface Vlan1
description [MyLAN]
ip address 10.0.0.1 255.0.0.0
ip nat inside
ip nat enable
ip local pool PPTP-Pool 10.0.1.10 10.0.1.99
ip default-gateway 192.168.1.1
ip forward-protocol nd
no ip http server
ip http access-class 1
ip http authentication local
no ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip dns server
ip nat inside source list 1 interface FastEthernet4 overload
ip nat inside source static tcp 10.0.0.21 21 192.168.1.253 21 extendable
ip nat inside source static tcp 10.0.0.21 80 192.168.1.253 80 extendable
ip nat inside source static tcp 10.0.0.21 8080 192.168.1.253 8080 extendable
ip route 0.0.0.0 0.0.0.0 192.168.1.1
access-list 1 permit 10.0.0.0 0.255.255.255
no cdp run
banner exec ^C
% Password expiration warning.
Cisco Configuration Professional (Cisco CP) is installed on this device
and it provides the default username "cisco" for  one-time use. If you have
already used the username "cisco" to login to the router and your IOS image
supports the "one-time" user option, then this username has already expired.
You will not be able to login to the router with this username after you exit
this session.
It is strongly suggested that you create a new username with a privilege level
of 15 using the following command.
username <myuser> privilege 15 secret 0 <mypassword>
Replace <myuser> and <mypassword> with the username and password you
want to use.
^C
banner login ^C
Cisco Configuration Professional (Cisco CP) is installed on this device.
This feature requires the one-time use of the username "cisco" with the
password "cisco". These default credentials have a privilege level of 15.
YOU MUST USE CISCO CP or the CISCO IOS CLI TO CHANGE THESE
PUBLICLY-KNOWN CREDENTIALS
Here are the Cisco IOS commands.
no username cisco
Replace <myuser> and <mypassword> with the username and password you want
to use.
IF YOU DO NOT CHANGE THE PUBLICLY-KNOWN CREDENTIALS, YOU WILL
NOT BE ABLE TO LOG INTO THE DEVICE AGAIN AFTER YOU HAVE LOGGED OFF.
For more information about Cisco CP please follow the instructions in the
QUICK START GUIDE for your router or go to http://www.cisco.com/go/ciscocp
^C
line con 0
login local
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport input all
line vty 0 4
access-class 1 in
privilege level 15
password [blabla]
login
transport input telnet ssh
end
Router#
Moreover, this is the "show ip route" command:
Router#show ip route
Codes: L - local, C - connected, S - static, R - RIP, M - mobile, B - BGP
       D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
       N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
       E1 - OSPF external type 1, E2 - OSPF external type 2
       i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
       ia - IS-IS inter area, * - candidate default, U - per-user static route
       o - ODR, P - periodic downloaded static route, H - NHRP, l - LISP
       + - replicated route, % - next hop override
Gateway of last resort is 192.168.1.1 to network 0.0.0.0
S*    0.0.0.0/0 [1/0] via 192.168.1.1
      10.0.0.0/8 is variably subnetted, 3 subnets, 2 masks
C        10.0.0.0/8 is directly connected, Vlan1
L        10.0.0.1/32 is directly connected, Vlan1
C        10.0.0.102/32 is directly connected, Virtual-Access3
      192.168.1.0/24 is variably subnetted, 2 subnets, 2 masks
C        192.168.1.0/24 is directly connected, FastEthernet4
L        192.168.1.253/32 is directly connected, FastEthernet4
Router#
Please give me a solution because I'm going crazy.
Leonardo
0 Replies 0
