IE-3000-4TC with GLC-FE-100LX-RGD SFP Modules
I need to better understand this equipment in the areas of minimum optical power input thru the fiber optic connections.
marce1000
 Ref : https://www.cisco.com/c/en/us/products/collateral/switches/industrial-ethernet-3000-series-switches/data_sheet_c78-440930.html
  In table 6. you will find the supported distance , for the rest connectivity will depend on optical-standards concerning db-power level.
 M.
Table 6.       SFP transceivers support for Cisco IE 3000 Series switches
Part number
Specification
SFP type
Max distance
Cable type
Temp range*
DOM support
GLC-FE-100FX-RGD=
100BASE-FX
FE
2km
MMF
IND
Yes
GLC-FE-100LX-RGD
100BASE-LX10
FE
10km
SMF
IND
Yes
GLC-FE-T-I=
100BASE-T
FE
100m
Copper
IND
NA
GLC-FE-100FX=
100BASE-FX
FE
2km
MMF
COM
No
GLC-FE-100LX=
100BASE-LX10
FE
10km
SMF
COM
No
GLC-FE-100EX=
100BASE-EX
FE
40km
SMF
COM
No
GLC-FE-100ZX=
100BASE-ZX
FE
80km
SMF
COM
No
GLC-FE-100BX-D=
100BASE-BX10
FE
10km
SMF
COM
No
GLC-FE-100BX-U=
100BASE-BX10
FE
10km
SMF
COM
Yes
GLC-SX-MM-RGD=
1000BASE-SX
GE
550m
MMF
IND
Yes
GLC-LX-SM-RGD=
1000BASE-LX/LH
GE
550m/10km
MMF/SMF
IND
Yes
GLC-ZX-SM-RGD=
1000BASE-ZX
GE
70km
SMF
IND
Yes
GLC-BX40-U-I=
1000BASE-BX40
GE
40km
SMF
IND
Yes
GLC-BX40-D-I=
1000BASE-BX40
GE
40km
SMF
IND
Yes
GLC-BX40-DA-I=
1000BASE-BX40
GE
40km
SMF
IND
Yes
GLC-BX80-U-I=
1000BASE-BX80
GE
80km
SMF
IND
Yes
GLC-BX80-D-I=
1000BASE-BX80
GE
80km
SMF
IND
Yes
GLC-SX-MMD=
1000BASE-SX
GE
550m
MMF
EXT
Yes
GLC-LH-SMD=
1000BASE-LX/LH
GE
550m/10km
MMF/SMF
EXT
Yes
GLC-EX-SMD=
1000BASE-EX
GE
40km
SMF
EXT
Yes
GLC-ZX-SMD=
1000BASE-ZX
GE
70km
SMF
EXT
Yes
GLC-BX-D=
1000BASE-BX10
GE
10km
SMF
COM
Yes
GLC-BX-U=
1000BASE-BX10
GE
10km
SMF
COM
Yes
CWDM-SFP-xxxx= (8 freq)
CWDM 1000BASE-X
GE
SMF
COM
Yes
DWDM-SFP-xxxx= (40 freq)
DWDM 1000BASE-X
GE
SMF
COM
Yes
SFP-GE-S=
1000BASE-SX
GE
550m
MMF
EXT
Yes
SFP-GE-L=
1000BASE-LX/LH
GE
550m/10km
MMF/SMF
EXT
Yes
SFP-GE-Z=
1000BASE-ZX
GE
70km
SMF
EXT
Yes
GLC-SX-MM=
1000BASE-SX
GE
550m
MMF
COM
No
GLC-LH-SM=
1000BASE-LX/LH
GE
550m/10km
MMF/SMF
COM
No
GLC-ZX-SM=
1000BASE-ZX
GE
70km
SMF
COM
Yes
GLC-TE=
1000BASE-T
GE
100m
Copper
EXT
NA
GLC-T=
1000BASE-T
GE
100m
Copper
COM
NA
GLC-T-RGD=
1000BASE-T
GE
100m
Copper
IND
NA
Note:    For DOM support and for first software release supporting SFP, refer to https://www.cisco.com/en/US/products/hw/modules/ps5455/products_device_support_tables_list.html.
*If nonindustrial EXT, COM) SFPs are used, the switch operating temperature must be derated.
Table 7.       Compliance specifications
Description
Specification
Standard safety certifications
●  UL 60950-1
●  CSA C22.2 No. 60950-1
●  TUV/GS to EN 60950-1
●  CB to IEC 60950-1 with all country deviations
●  NOM
Mechanical stability
●  IEC 60628-2-27 Shock 20g (operational), 30g (nonoperational)
Electromagnetic emissions
●  FCC Part 15 Class A
●  EN 55022
●  CISPR 22
●  CISPR11
●  VCCI Class A
●  AS/NZS 3548 Class A
●  CNS 13438 Class A
●  KN 22 Class A
Electromagnetic immunity
●  EN 55024
●  AS/NZS CISPR 24
●  KN 24
●  IEC/EN 61000-4-2 (Electro Static Discharge)
●  IEC/EN 61000-4-3 (Radiated Immunity)
●  IEC/EN 61000-4-4 (Fast Transients)
●  IEC/EN 61000-4-5 (Surge)
●  IEC/EN 61000-4-6 (Conducted Immunity)
●  IEC/EN 61000-4-8 (Power Frequency Magnetic Field Immunity)
●  IEC/EN 61000-4-9 (Pulse Magnetic Field Immunity)
●  IEC/EN 61000-4-10 (Oscillatory Magnetic Field Immunity)
●  IEC/EN 61000-4-11 (AC power Voltage Immunity)
●  IEC/EN 61000-4-16 (Low Frequency Conducted CM Disturbances)
●  IEC/EN 61000-4-17 (Ripple on DC Input Power)
●  IEC/EN 61000-4-18 (Damped Oscillatory Wave)
●  IEC/EN 61000-4-29 (Voltage Dips Immunity, DC power)
●  IEEE C37.90 (Surge)
●  IEEE C37.90.1 (Fast Transients)
●  IEEE C37.90.2 (Radiated Immunity)
●  IEEE C37.90.3 (Electro Static Discharge)
Industry specifications
●  EN 61131-2 Programmable Controllers (EMC/EMI, environmental, mechanical)
●  IEEE 1613 Power Station and Substation Networking Devices
●  IEC 61850-3 Power Station and Substation Communication Networks and Systems
●  EN 61326-1 Electrical Equipment for Measurement, Control and Laboratory Use - EMC
●  EN 61000-6-1 Immunity for Light Industrial Environments
●  EN 61000-6-2 Immunity for Industrial Environments
●  EN 61000-6-4 Emissions for Industrial Environments
●  TS 61000-6-5 EMC Immunity for Power Station and Substation
●  EN 50155 Railway, Electronic Equipment on Rolling Stock (EMI/EMC, environmental, mechanical)
●  EN 50121-3-2 Railway, Electromagnetic Compatibility on Rolling Stock
●  EN 50121-4 Railway, Emission and Immunity of Signaling and Telecommunications Apparatus
●  EN 60945 Maritime Navigation and Radio-communication Equipment and Systems
●  IEC 60533 Shipboard Electrical and Electronic Installation EMC
●  Marine Type Approval (BV, DNV, Korean Register, Lloyd Register)
●  NEMA TS-2 (EMC, environmental, mechanical)
●  ABB Industrial IT certification
●  ODVA Industrial EtherNet/IP support
●  PROFINETv2 support
●  Directive 2011/65/EU RoHS
●  IP20
Hazardous locations
●  UL/CSA 60079-0, -15 (Class 1, Div 2 A-D) (requires cabinet enclosure)
●  EN 60079-0, -15 ATEX Certification (Class 1, Zone 2 A-D) (requires cabinet enclosure)
●  IEC 60079-0, -15 (Test report only) (requires cabinet enclosure)
●  UL 508
●  CSA C22.2 No. 142
Compliance marking
●  UL/CSA
●  CE (Europe)
●  C-Tick (Australia/New Zealand)
●  KCC (Korea)
●  ANATEL (Brazil)
●  China RoHS
Operating temperature
●  -40 C to +70 C (vented enclosure operating)
●  -40 C to +60 C (sealed enclosure operating)
●  -34 C to +75 C (fan or blower-equipped enclosure operating)
●  -40 C to +85 C (IEC Environmental Type Testing, 16 hours)
●  Operational altitude: Up to 13,000 ft
Storage temperature
●  -40 C to +85 C (storage temperature)
●  Storage altitude: Up to 15,000 ft
Humidity
●  Relative humidity: 5% to 95% non-condensing
Telco
●  Common Language Equipment Identifier (CLEI) code
Warranty
●  Five year limited warranty
Service and support
Cisco is committed to minimizing Total Cost of Ownership (TCO). The company offers a portfolio of technical support services to help ensure that its products operate efficiently, remain highly available, and benefit from the most up- to-date system software. The services and support programs described in Table 8 are available as part of the Cisco Desktop Switching Service and Support solution and are available directly from Cisco and through resellers.
Table 8.       Cisco Services and support programs
Service and support
Features
Benefits
Advanced Services
●  Cisco Total Implementation Solutions (TIS), available direct from Cisco
●  Cisco Packaged TIS, available through resellers
●  Cisco SMARTnet ® and SMARTnet Onsite support, available direct from Cisco
●  Cisco Packaged SMARTnet support program, available through resellers
●  Cisco SMB Support Assistant
●  Project management
●  Site survey, configuration, and deployment
●  Installation, text, and cutover
●  Training
●  Major moves, adds, and changes
●  Design review and product staging
●  Access to software updates 24 hours
●  Web access to technical repositories
●  Telephone support through the Cisco Technical Assistance Center (TAC)
●  Advance replacement of hardware parts
●  Supplements existing staff
●  Helps ensure that functions meet needs
●  Mitigates risk
●  Helps enable proactive or expedited issue resolution
●  Lowers TCO by taking advantage of Cisco expertise and knowledge
●  Minimizes network downtime
Ordering information
Table 9 gives ordering information for the Cisco IE 3000 Series.
Table 9.       Ordering Information for Cisco IE 3000 Series
Description
Specification
IE-3000-4TC
●  Industrial Ethernet switch
●  4 Ethernet 10/100 ports and 2 dual-purpose uplinks (each dual-purpose uplink port has 1 10/100/1000 Ethernet port and 1 SFP-based Gigabit Ethernet port, 1 port active)
●  Each switch supports 2 Cisco modules, 1 Cisco IEM-3000-8FM= module, or 1 Cisco IEM-3000-8TM= module and 1 Cisco IEM-3000-8FM= module
●  Layer 2 LAN Base image installed
IE-3000-8TC
●  8 Ethernet 10/100 ports and 2 dual-purpose uplinks (each dual-purpose uplink port has 1 10/100/1000 Ethernet port and 1 SFP-based Gigabit Ethernet port, 1 port active)
●  Each switch supports 2 Cisco IEM-3000-8TM= modules, 1 Cisco IEM-3000-8FM= module, or 1 Cisco IEM-3000-8TM= module and 1 Cisco IEM-3000-8FM= module
IE-3000-4TC-E
●  Layer 3 IP Services image installed
IE-3000-8TC-E
IEM-3000-8TM=
●  Expansion Copper module for Cisco IE-3000-4TC and IE-3000-8TC switches
●  8 10/100 TX ports
IEM-3000-8FM=
●  Expansion Fiber module for Cisco IE-3000-4TC and IE-3000-8TC switches
●  8 100 FX ports
IEM-3000-4SM=
●  Expansion SFP module for Cisco IE-3000-4TC and IE-3000-8TC switches
●  4 100M SFP ports
IEM-3000-8SM=
●  8 100M SFP ports
IEM-3000-4PC=
●  Expansion PoE/PoE+ module for Cisco IE-3000-4TC and IE-3000-8TC switches
●  4 10/100 PoE/PoE+ ports
●  External PoE power source (44-57 VDC for PoE/50-57 VDC for PoE+)
IEM-3000-4PC-4TC=
●  4 non-PoE ports and 4 10/100 PoE/PoE+ ports
PWR-IE50W-AC=
●  Expansion power module for IE-3000-4TC and IE-3000-8TC switches
PWR-IE50W-AC-IEC=
PWR-IE65W-PC-AC=
●  AC-DC, 54VDC power module to support 65 watts for PoE/PoE+ modules
PWR-IE65W-PC-DC=
●  DC-DC, 54VDC power module to support 65 watts for PoE/PoE+ modules
CAB-SM-LCSC-1M
●  1m-fiber single-mode LC-to-SC connectors
CAB-SM-LCSC-5M
●  5m-fiber single-mode LC-to-SC connectors
CF-IE3000=
●  IE 3000 Compact Flash
PWR-IE3000-CLP=
●  IE 3000 Power Transformer Spare connector clip
PWR-IE3000-CNCT=
●  IE 3000 Power Spare connector
LPNL-IE3000=
●  IE 3000 Left Panel Spare
RPNL-IE3000=
●  IE 3000 Right Panel Spare
DINCLP-IE3000=
●  Din-rail clip 4 pack Spare
BMP-IE3000=
●  Din-rail clip bumper 4 pack Spare
STK-RACKMNT-2955=
●  Din-rail adapter for rack mounting
IE-SW-SPARE
●  Spare IOS software upgrade part number (L2 to L3 features)
IE3000-DNA-E-L
●  DNA Essentials license
IE3000-DNA-E-L-3Y
●  DNA Essentials 3-year term license option
IE3000-DNA-E-L-5Y
●  DNA Essentials 5-year term license option
Figure 1.      IE3000 base module dimensions
Figure 2.      IE3000 expansion module dimensions
For more information about Cisco products, contact:
●   United States and Canada: 800 553-6387
●   Europe: 32 2 778 4242
●   Australia: 612 9935 4107
●   Other: 408 526-7209
●   URL: https://www.cisco.com
Cisco Capital
Flexible payment solutions to help you achieve your objectives.
Cisco Capital makes it easier to get the right technology to achieve your objectives, enable business transformation and help you stay competitive. We can help you reduce the total cost of ownership, conserve capital, and accelerate growth. In more than 100 countries, our flexible payment solutions can help you acquire hardware, software, services and complementary third-party equipment in easy, predictable payments. Learn more.
Contact Cisco
Viewers of This Document Also Viewed
Was this Document Helpful?
Yes No
