NTP Configuration
croftsd23
Frequent Visitor
Frequent Visitor
I am looking at NTP configuration and have the following configuration:-
ip access-list standard NTP
permit x.x.x.x
deny   any log
access-list 23 deny   any log
ntp access-group peer NTP
ntp access-group serve-only 23
ntp server  prefer x.x.x.x
The result I am seeing is that when I apply debug I can see downward devices getting blocked.  However, the devices do appear to be getting a response from the server.  There lies my confusion.
Mark Elsen
 access-list 23 deny   any log ->  Doesn't that overall-deny match first ?
 M.
-- ' Listen to the wind, it talks
          Listen to the silence, it speaks
             Listen to your heart, it knows
Ganado Mucho (1809 to 1893 ) Navajo Indian
Thanks for the reply.  I see the configuration working as follows:-
The switch is able to peer with the NTP server but due to the deny access list, all downward devices attempting to get a time source should fail.  I see blocks in the log.  However, the devices are getting a time reply?
