ifIndex persistence in NX-OS
mraful
From what I have read on line, it appears that by default the Nexus Switches, at least the 7k, has ifIndex persistence by default.  Can anyone confirm this?
Thanks!!
Mitch
Giuseppe Larosa
Hello Mitch,
it looks like you are right see the following page
https://www.cisco.com/c/en/us/td/docs/switches/datacenter/sw/5_x/nx-os/system_management/configuration/guide/sm_nx_os_cg/sm_9snmp.html#56568
Displays the persistent SNMP ifIndex value from IF-MIB for all interfaces. Optionally, use the | keyword and the grep keyword to search for a particular interface in the output.
I don't know for other Nexus platforms but Nexus 7000 should support it by default as explained in the link above.
Hope to help
Giuseppe
