ignored errors
mrwilson05
Community Member
On a customer router their receiving input errors which are all ignored errors, ISP advised they are not seeing any issues on thier end.
Will increasing the buffer size or input que size solve this problem?
Interface stats:
Ethernet1/0 is up, line protocol is up
MTU 1500 bytes, BW 512 Kbit, DLY 1000 usec,
reliability 255/255, txload 1/255, rxload 138/255
Last clearing of "show interface" counters 2d17h
7827230 packets input, 2584052412 bytes, 160 no buffer
Received 867143 broadcasts, 0 runts, 0 giants, 0 throttles
10510 input errors, 2 CRC, 2 frame, 0 overrun, 10508 ignored
3570356 packets output, 614777589 bytes, 0 underruns
Fernando_Meza
Level 11
Level 11
what is the router's interface E1/0 connected to ..?
I suggest you to perform a physical check to make sure the cables are OK. The router has input errors which could be comming from the device that is directly linked to the E1/0 interface ..
I hope it helps ... pleasa rate it if it does !!
