10-15-2020 10:07 AM
This may be a somewhat unique environment that we are experiencing this problem. We are developing a PoE tester and after many iterations of PoE negotiations, this error will appear. Once this error appears, the port will no longer succeed when we attempt to negotiation again for PoE.
Does anyone have more information on what the critical fault actually is in this scenario? From Cisco documentation:
7. SINGLE PAIRSET FAULT %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/1, changed state to up %ILPOWER-5-SINGLE_PAIRSET_FAULT: Interface Gi1/0/1: shutting down Alt-B pairset due to OVERCLS fault %ILPOWER-5-SINGLE_PAIRSET_FAULT: Interface Gi1/0/1: shutting down Alt-B pairset due to OVERCLS fault This error means that the dual signature powered device on the switchport has hit a critical fault on one pairset and hence that pairset will be shutdown. Example above is taken from a UPoE+ capable powered device & switch.
This doesn't give any insight into what DISCONNECT means in the above scenario unforunately.
10-15-2020 02:27 PM
What switch model number?
10-15-2020 03:02 PM
C9404R-48U-BNDL-E
10-15-2020 06:43 PM
Do the following:
test cable tdr interface Gi1/0/1
Wait for approximately 60 seconds for the test to run.
show cable tdr interface Gi1/0/1
And then post the complete output from the last command.
10-16-2020 08:36 AM
Happy to run the command and provide the output once I'm able to reproduce this setup. I will update w/ a reply once this is possible!
I'll provide a bit more information- we can do thousands of PoE negotiations with this switch without any problem, but once we begin utilizing LLDP for PoE negotiations, after a varying amount of runs the switch will show this error.
I'm really looking for more information on what exactly this DISCONNECT problem is referring to with regards to PoE.
10-16-2020 08:48 AM - edited 10-16-2020 08:49 AM
Cisco-C9404R-Class8#show cable tdr interface Gi1/0/24 TDR test last run on: October 16 08:47:56 Interface Speed Local pair Pair length Remote pair Pair status --------- ----- ---------- ------------------ ----------- -------------------- Gi1/0/24 1000M Pair A 10 +/- 10 meters Pair A Normal Pair B 9 +/- 10 meters Pair B Normal Pair C 9 +/- 10 meters Pair C Normal Pair D 9 +/- 10 meters Pair D Normal
10-16-2020 05:49 PM
TDR output looks good.
Wait ... LLDP?
IOS-XE, 3.650/3850 and Catalyst 9k, do not like LLDP and CDP running simultaneously. Unlike "classic" IOS, which LLDP and CDP can work harmoniously, if LLDP is required then CDP must be disabled on each port/interface.
10-20-2020 03:23 PM
10-20-2020 10:18 PM
What firmware is the chassis running on?
10-21-2020 09:20 AM
Cisco-C9404R-Class8#show version Cisco IOS XE Software, Version 16.12.02 Cisco IOS Software [Gibraltar], Catalyst L3 Switch Software (CAT9K_IOSXE), Version 16.12.02, RELEASE SOFTWARE (fc2) Technical Support: http://www.cisco.com/techsupport Copyright (c) 1986-2019 by Cisco Systems, Inc. Compiled Tue 19-Nov-19 10:04 by mcpre
10-21-2020 04:43 PM
Hmmmm ... 16.12.2.
May I ask if it is possible to upgrade to 16.12.4? If it is possible, may I also ask that the chassis have a COLD REBOOT (instead of the "reload" command)?
NOTE: COLD REBOOT is physically powering down the entire chassis, wait for 5 seconds and then powering the chassis back up.
