Implementing CEoIP
jcdx_jicpac
I am trying to implement CEoIP using the CEM-4SER module on a 2651XM router. I have been able to get the channels to sync properly. However, regardless of what I change in the IOS settings, I continue to get a 3-5% error rate during transmission. I have confirmed that the same serial line without the CEM modules installed has a 0% error rate. Does anyone have any successful experiences with this module?
sbilgi
Level 5
Level 5
not sure of the issue, check out the following link on configuring Circuit Emulation over IP :
http://www.cisco.com/en/US/products/sw/iosswrel/ps5207/products_feature_guide09186a00801ee181.html
hope this helps.
I was looking for someone with real life experience. I was able to do a search on the cisco web site and find this page. Without this information my error rate would probably be 97% or higher.
I am curious to see if you found any cure to your problem, I probably have the same error rate, around 3%
